Biggest wheels/tires with no modifications
Old Jul 13, 2011 | 04:25 PM
DakotaAgain?'s Avatar
DakotaAgain?
Default Biggest wheels/tires with no modifications
I have the stock 245/70/16 Goodyears on my 08. How far can I go without needing any mods?
Old Jul 13, 2011 | 04:34 PM
dakotaff's Avatar
dakotaff
Assuming you're sticking with 16" wheels, 265/70/16 will fit 100% fine. Going up to 265/75/16 may fit, but you'll most likely need to do some trimming.
Old Jul 13, 2011 | 05:15 PM
Eimer123's Avatar
Eimer123
I have 265/75/16 they fit fine stock.
Old Jul 13, 2011 | 05:41 PM
rengnath's Avatar
rengnath
265/70/16s had a 1/4" of clearance with the front mud flaps on my truck before leveling the front. With a 1.5" leveling kit, I have alot more clearance. If you want to do any large tires/wheels, I suggest you invest in a leveling kit.
Old Jul 13, 2011 | 06:25 PM
Backwoods18's Avatar
Backwoods18
I too have 265/75/16's. They fit fine without a leveling kit.
Old Jul 13, 2011 | 08:26 PM
DakotaAgain?
What about bigger wheels? Looks like everybody has stuck with 16". I'd rather not mess with kits etc. I don't know the right person to do it and there are always some side effects.
Old Jul 13, 2011 | 10:30 PM
dakotaff's Avatar
dakotaff
You can go up to 20" wheels, if you want. I'm running 20's, you just need to have a smaller sidewall. 265/50/20 fit on stock suspension, guys here are running anywhere from 16" to 20" wheels.
Old Jul 14, 2011 | 01:07 PM
DakotaAgain?
I did not see a truck tires in that size. I like something like BFGoodrich All-Terrain T/A. What measurements should I look at when going with larger wheels?
Old Jul 14, 2011 | 02:31 PM
rengnath's Avatar
rengnath
Easiest thing to do is to use a calculator like this one:
http://www.1010tires.com/tiresizecalculator.asp
Type in what sizes were suggested for a 16" wheel, and compare them to different sizes available for bigger wheels. Use places like tirerack.com and tiredepot.com, or tire manufacturer websites to find the tire sizes that are available in a specific tread pattern.
Old Jul 14, 2011 | 02:45 PM
dodgedad80's Avatar
dodgedad80
265/75/16's will fit nice. But 70's will fit w/out any cutting. Once u go bigger wheels it may change the offset and make it rub. It did on mine.
