oil change!
Old Jul 16, 2011 | 12:42 PM
Six_Shooter's Avatar
Six_Shooter
Originally Posted by Deer Hunter
I think only the 3.7s have that
That could be.
Old Jul 16, 2011 | 01:01 PM
Deer Hunter's Avatar
Deer Hunter
Originally Posted by Six_Shooter
Why does an oil change in the Dak take an hour? I do it in less than 15 minutes on a hoist, it would be less than 20 if I had to do it on the ground, using a jack and jack stands.
I do 15 min on the ground. But, I'm slim so I can easily slide right under the truck and I have the Fumoto valve and drain tube.
On a side note; starting fluid spayed on oil and trans spills lifts the spill right up. Spray and blot it up in small enough sections that you can do it before the ether evaporates. Bada bing, no stain on driveway.
