wheel spacers
Old Jul 19, 2011 | 10:27 PM
marcsnyder05's Avatar
marcsnyder05
Default wheel spacers
So has anyone used wheel spacers before? I was thinking about getting some to put my wheels out away from the frame some so my tires will quit rubbing at full turn.
Old Jul 19, 2011 | 10:29 PM
Dakkkota's Avatar
Dakkkota
1/4 with terrible result vibrating
Old Jul 19, 2011 | 10:31 PM
Dakkkota's Avatar
Dakkkota
i still have some minor rubbing with 16x8 offset 0 (+1'') than stock
Old Jul 19, 2011 | 10:48 PM
thunder98110's Avatar
thunder98110
not the best idea if you offroad, weakens the hub from what i understand...
Old Jul 19, 2011 | 10:53 PM
wingman_214's Avatar
wingman_214
Bad idea. They tend to wallow out and let the wheel nuts loosen.
Old Jul 19, 2011 | 10:55 PM
marcsnyder05
sweet ill cancel that idea then. thanks guys
Old Jul 20, 2011 | 02:16 AM
sleds's Avatar
sleds
depends if you put on the wheel spacers like dakkkota did or if you get the wheel adapter spacers. I put on the wheel adapter spacers. The ones I put on were a straight 5 on 5.5" to 5 on 5.5" obviously, 1.25" on the front and 2" on the rear. I had to do some fairly serious trimming to do it, but it works perfectly now. I did it with the stock wheels and for the same reason as I was tired of the frame rub. I'll try to post up some pics in the next couple of days.
Old Jul 20, 2011 | 04:27 PM
projektdirtfab's Avatar
projektdirtfab
real wheel spacers are ok and hold up. you have to get the ones that bolt on to the studs and then clock the new studs in a different location. those hold up to the moab jeep guys torture
Old Jul 20, 2011 | 07:02 PM
marcsnyder05
Sweet cause that is the type I was looking at getting. sleds where did you get yours?
Old Jul 21, 2011 | 01:34 AM
sleds's Avatar
sleds
Here are a few pictures of the process.
Before pic
a couple during
and a couple after. Just shows the difference of the offset.
