stereo gurus need help!
Old Jul 22, 2011 | 10:35 PM
BAdassR/T's Avatar
BAdassR/T
Default stereo gurus need help!
ok so i just put in a new head unit into my truck with one of those easy connectors that you dont have to cut into you stock wiring, and when i plug everything in i notice a blue light come on for the headunit but the screen wont turn on. tried resetting it, nothing. any ideas wtf could be wrong i already sent back the same head unit for the exact problem. checked the ground thats fine. any ideas whats wrong here?
heres the unit i bought,
http://www.audiosavings.com/products...TID7002NR.aspx
im going to be trying tomorrow running a wire straight from the battery to the unit and see if that works. im pretty much lost at this point.
Old Jul 22, 2011 | 10:50 PM
rengnath's Avatar
rengnath
I believe the power wire going to the head unit is always hot, and then there is a wire that tells the radio when the ignition is on. Sorry, I don't know the technical terms, but that may be a start to figuring out what the problem is. I assume the blue light is always on, regardless of the ignition?
Old Jul 22, 2011 | 10:53 PM
BAdassR/T's Avatar
BAdassR/T
No the blue light only comes on when powered or the unit is reset. Those 2 wires you are talking about are the battery and ignition. Both hooked up correctly
Old Jul 22, 2011 | 11:14 PM
not sure, but i'd like to see how you installed it...any pics?
Old Jul 23, 2011 | 12:42 AM
Altair's Avatar
Altair
Dak attack!
I'm guessing the harness you bought isn't giving you a switched power source to indicate to the radio that the truck is on (stock unit gets a signal for this over the CAN-BUS if I remember correctly). Take a look at this thread, specifically Eric's and Monkey's suggestions: https://dodgeforum.com/forum/3rd-gen...head-unit.html
Old Jul 23, 2011 | 06:38 AM
BAdassR/T's Avatar
BAdassR/T
Interesting. So is the entire harness crap? Running power off the cig lighter is no problem. The unit does get power tho, my guess is it just doesn't get enough.
Old Jul 23, 2011 | 08:20 AM
BAdassR/T's Avatar
BAdassR/T
Anyone know which wire on the cig lighter is the hot one ?
Old Jul 23, 2011 | 09:46 AM
rengnath's Avatar
rengnath
The one with the white stripe. Atleast I believe mine had a white stripe on it. Solid colors should always be ground when the hot has a stripe.
Old Jul 23, 2011 | 10:02 AM
ballsout's Avatar
ballsout
with the stripe is hot, that should fix your issue, i hooked mine up with one of those kits as well and took the wire from the lighter.
Old Jul 23, 2011 | 10:36 AM
BAdassR/T's Avatar
BAdassR/T
Sweet thanks guys. I'm giving my truck a little update so I'll be posting new pictures soon
