CAI question
Old Aug 4, 2011 | 06:38 PM
kbond's Avatar
kbond
Default CAI question
is the 4.7l intake the same for the 3.7l dakota? on a 2010 3rd gen?
looking at buying one but they only seem to be listed for the 4.7 engines.
thanks in advanced.
kent.
Old Aug 4, 2011 | 09:11 PM
Reject's Avatar
Reject
I believe they are the same, but not 100% sure on it. I have a 3.7L
I Bought mine on Ebay, and I think it said 3.7 and 4.7
Old Aug 4, 2011 | 09:22 PM
Hammond_Egger's Avatar
Hammond_Egger
The 3.7L is the 4.7L with the front 2 cylinders chopped off (or maybe the 4.7L is the 3.7L with 2 extra cylinders stuck on the front!)
Either way you look at it, the CAI will fit!.
Old Aug 5, 2011 | 07:22 AM
Backwoods18's Avatar
Backwoods18
You nailed it. The any CAI for the 4.7 will fit the 3.7
Old Aug 5, 2011 | 09:27 AM
rengnath's Avatar
rengnath
Yup, the only reason why some companies don't state their intake will fit the 3.7l is because they haven't test fitted it on a truck with the v6, and they don't want to risk it not fitting if they list it as compatible.
Old Aug 5, 2011 | 01:06 PM
keithhud's Avatar
keithhud
How are the smog inspection rules in Canada?
The reason I ask is, here in California if you install a CAI or any aftermarket product for an engine you need a manufactures sticker that says it's approved for X engine type to be used in California.
I ran into this issue when I had my 01 Dak with the 3.9L engine. I had installed a K&N CAI on it right after I got the truck. When smog time came the smog inspectors said hey “where is your manufactures sticker for your CAI”? They told me they couldn’t smog it until I had a sticker. I talked with a buddy of mine that said just call K&N and they will send you the sticker. I called K&N and they tell me sorry we never made a CAI for that motor. So $65 latter I had an OEM CAI from Pick and Pull and was able to get the Dak smogged.
With 08 Dak I ended up creating my own CAI and set my OEM CAI in the Garage. So when I take it to the stealership I swap it out takes me all of 5 minutes.
Good Luck.
