rear sway bar end links
Old Aug 16, 2011 | 08:50 PM
gjmoran's Avatar
gjmoran
Default rear sway bar end links
i went under my truck today and grabbed on to them and shook the hell out of them and i have a tiny bit of play in them... like enough to make it click by shaking it hard enough. does this mean they are bad and is the reason i feel like i am going to fly into the next lane when i hit rough patches on the freeway? how hard of a replacement is it and is there some better replacement part than the one on the autozone website?
Old Aug 16, 2011 | 08:54 PM
Took me about a half hour mostly because the bolts were rusty. I got mine off rock auto.
Old Aug 16, 2011 | 08:56 PM
gjmoran's Avatar
gjmoran
but are they bad? i was under the impression they shouldnt be any movement at ALL
Old Aug 16, 2011 | 11:43 PM
gjmoran's Avatar
gjmoran
anyone?
Old Aug 17, 2011 | 06:58 AM
Eimer123's Avatar
Eimer123
Rear links, I would say should have no rattle play, you may be able to squish the rubber/poly bushing a little bit.
Old Aug 17, 2011 | 09:10 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
It should move very little... it depends on the amount of movement you get. If it was rock solid you'd break something.
Old Aug 17, 2011 | 05:39 PM
gjmoran's Avatar
gjmoran
i would say a few millimeters play. enough where if i give it a good shake i can tap it back and forth making it click when it hits
Old Aug 17, 2011 | 06:38 PM
My left side had a seized bolt/bushing and it was squeeking so I just replaced them both.
Old Aug 18, 2011 | 09:43 AM
lghtngblt02
OH!... thats too much, lol Sounds like you found your issue, either way!
