trans fluid question
Old Aug 20, 2011 | 08:14 PM
Jaded's Avatar
Jaded
I've always drained the torque converter. Even go as far as pulling off the lines to the trans cooler, but I'm no expert. Just never made sense to change 4 quarts and a filter to me. It'd be like dropping a quart of your engine oil, changing the filter, refilling and calling it good. But I'm no expert and may be throwing money away.
Old Oct 19, 2011 | 08:42 PM
sdtalon's Avatar
sdtalon
I haven't changed fluid in an automatic before, but i've heard you need drain the torque converter. How do you drain it? I know mechanics have some machine that cycles the old oil out while feeding in new oil so it all gets cleaned, but obviously I dont have one of those machines and i'd like to keep my costs down so i'd like to do it myself if i can.
Thanks.
Old Oct 19, 2011 | 09:47 PM
JimBio's Avatar
JimBio
Just did mine, took 7 qts Valvoline Synthetic ($6.50/qt.) on a pan drop/filter change. Not to bad of a job, the fluid was clean as a whistle coming out and very little sludge on the magnet (58,000 miles). Got a little worried that it wouldn't clear the exhaust, but it squeezed by.
