******j m r s n e e k p e e k ******
Old Aug 24, 2011 | 12:45 AM
sleds's Avatar
sleds
Originally Posted by jkeaton
i have to say...what is up with the top of the strut? looks weak with that..
Nope, that is legit. Most companys do that. Steering is in the normal spot, no steering drop. That is good. Heavy duty construction everywhere, angles all good. Sway bar is gone, probably o.k. Don't need it for offroading, but how does that affect the on road handling? Looks awesome!!
4" diff drop? 6" with spacer would make it that. The top arm, is that stock? Good work.
Old Aug 24, 2011 | 06:47 AM
Backwoods18's Avatar
Backwoods18
Yea buddy!!
Old Aug 24, 2011 | 07:07 AM
Dakkkota's Avatar
Dakkkota
swaybar link spacer available on the kit...swaybar is removed for flexing test and the spacer is common look at all fabtech,superlift,RCX,zone etc..they all use a 4'' spacer for 6'' lift
Old Aug 24, 2011 | 07:09 AM
Dakkkota's Avatar
Dakkkota
the top arm is stock its the spindle that is longer so the angle is flat
Old Aug 24, 2011 | 07:11 AM
Cuban11182's Avatar
Cuban11182
How much will it be? When can we order!
Old Aug 24, 2011 | 07:12 AM
Backwoods18
Originally Posted by Dakkkota
desert rat need apologize from us!!!
For what? I never understood what happened and/or why he left DF. Was something said to him?
Old Aug 24, 2011 | 07:16 AM
Dakkkota's Avatar
Dakkkota
after all the negative comments...he left the DF but i kept contact with him and share infos. if there is to much negative comments the kit will probabely not release so be smooth :P the kit will be in the 2000$range but with fabtech ajustable coil over and option some more $$$
Old Aug 24, 2011 | 07:19 AM
Backwoods18
No bad comments from me. I don't have a problem with him.
Old Aug 24, 2011 | 08:05 AM
Cuban11182's Avatar
Cuban11182
That's doable! Where do I sign?
Who was it that said the bad comments? I'm guessing they are eating their words now.
Old Aug 24, 2011 | 08:50 AM
donkeypunch's Avatar
donkeypunch
King Jackass
This looks pretty solid. What is their website?
