Power window fuse
Old Aug 25, 2011 | 03:24 PM
remme's Avatar
remme
Default Power window fuse
Any one know where one might find it on a 2005 dak slt? not in fuse block under hood, and nowhere that I can find on or in the door w panel removed....am i going nuts?
Old Aug 25, 2011 | 03:36 PM
Backwoods18's Avatar
Backwoods18
I just looked and I can't find one either... hmmm
Old Aug 25, 2011 | 06:00 PM
Eimer123's Avatar
Eimer123
I have looked myself and even tried to remove some randoms that I thought would control them. I guess its integrated into the ignition switch
Old Aug 29, 2011 | 09:52 AM
remme's Avatar
remme
so sick and tired of this. both windows arent working from either switch. i refuse to believe either both motors, both relays or both switches just went bad all of a sudden. im gunna merk someone at dodge real fast if this keeps going ha
Old Aug 29, 2011 | 11:39 AM
There is no fuse. It's a circuit breaker.
Old Aug 29, 2011 | 03:58 PM
EliteTempleton's Avatar
EliteTempleton
Yep, in the Breaker Panel next to the diesel fuel conversion toggle.
Old Aug 29, 2011 | 08:19 PM
remme's Avatar
remme
so where si this circuit breaker and how do I fix it?
Old Aug 29, 2011 | 08:47 PM
page 77 of the service manual in the sticky section:
"The power window system includes the power window switches on each door trim panel, the circuit breaker, and the power window motors inside each door."
The service manual is a very useful resource and can be found here:
https://dodgeforum.com/forum/3rd-gen...s-manuals.html
Old Aug 29, 2011 | 09:18 PM
EliteTempleton
There really is a circuit breaker?! I gotta check out pg 77 when I get to my PC.
+1 on using the service manual for info.
Old Aug 29, 2011 | 10:18 PM
thats how all power windows work. the motor runs until window runs into a restriction (either the top or bottom of the door) and the breaker trips to cut power to the motor, then it resets itself. To the original poster, I would first check the wiring on the drivers side switches. Everything runs off those switches, if there is a loose connection in there, it will affect all the other switches.
