05 4.7 idle problems
Old Sep 11, 2011 | 11:38 PM
Dakota_05's Avatar
Dakota_05
Default 05 4.7 idle problems
So I have a 2005 Dakota 4.7. Occasionally at a stoplight or going through the drive thru, etc. my truck will start running rough and will sometimes die altogether. Any ideas on what I could be dealing with?
Old Sep 11, 2011 | 11:43 PM
thunder98110's Avatar
thunder98110
Hi, and WELCOME.
I would first start by checking the IAC and TPS, then my next guess would be spark plugs.
Old Sep 11, 2011 | 11:59 PM
Dakota_05's Avatar
Dakota_05
Thanks. I can rule out the plugs, I changed them pretty recently. But I'll definitely check out the others.
Old Sep 12, 2011 | 12:38 AM
welcome to the 3rd gendakota forum. Ditto what winston said. I would also disconnect the battery for an hour or so and also clean the IAC, and throttle body. When's the last time you replaced the plugs?
Old Sep 18, 2011 | 09:43 PM
Dakota_05's Avatar
Dakota_05
Sorry for the late reply, it's been around 10k miles or maybe less since the plugs were changed. Also, my truck seems only to have the idle problem when it's full or nearly full of gas.
