Seafoam
Old Sep 30, 2011 | 10:23 PM
Reject's Avatar
Reject
Originally Posted by damyankee84
It only develpos issue's if you put it in the crankcase to clean out the oil passages. Despite what that directions say DO NOT put it in with your oil. It will eat away any of the build up the oil seals which in turn cause it to leak. There is a thread like this on a jeep forum I'm on and it's probably 50 pages long with more good then bad (90%good vs 10%bad) stories about seafoam. As with any product there is always going to be some negative things about it. BUT this stuff does a decent job if used properly.
Yea thats what I heard, but what I read it never specified it was Oil only.
Old Oct 2, 2011 | 01:08 PM
gjmoran's Avatar
gjmoran
ive used it before, in my gas tank, booster line and crank case. didnt notice any difference. smoked a tiny bit but that was it..
Old Oct 3, 2011 | 04:46 PM
Dinger838's Avatar
Dinger838
on an older engine it could potentially lower compression as the carbon build up acts like a seal, i've done it on plenty of engines nothing bad happened yet, do it on the the brake booster line
Old Oct 3, 2011 | 08:14 PM
Hahns5.2's Avatar
Hahns5.2
Carbon doesn't seal up anything, it takes up volume therefor increasing the compression ratio.
