codepo2096
Old Oct 2, 2011 | 05:04 PM
flchipper's Avatar
flchipper
Default codepo2096
code po2096 on a 2008 dakota is becoming a real problem.what ares some causes and solutions.4.7 magnum engine.
Old Oct 2, 2011 | 11:12 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 3rd Generation Dakota Sub-Forum.
Old Oct 2, 2011 | 11:33 PM
Eimer123's Avatar
Eimer123
Trouble Code: P2096
Downstream Fuel System 1/2 Lean
Trouble Code Conditions:Engine running in closed loop mode. Ambient/battery temperature above 20F (-7C). Altitude below 8500 feet. Fuel level is more than 15%. If the PCM adds downstream short-term compensation to long-term adaptive, and a certain percentage is exceeded for 2 tr
Possible Causes:
  • Exhaust leak
  • Engine mechanical problem
  • O2 Sensor has failed
  • O2 Sensor signal circuit or return circuit problem
  • Fuel contamination
