rear abs speed sensor
Old Oct 2, 2011 | 12:40 PM
gjmoran's Avatar
gjmoran
Default rear abs speed sensor
i had a check engine light on the other day and went to a shop to get it read real quick and i forgot the exact code it threw but it was a U1### code. i remember the message, had something to do with the rear abs speed sensor or something like that.
when i searched it up on google i read some jeep guys who got the code reported having some voltage problems that would cause their cars/trucks to throw wierd codes when nothing was actually wrong.
the guy at the shop cleared the code and it hasnt came back, but it got me wondering..could it be possible i have voltage issues that is causing codes to be thrown? i had a check engine light about 2 months ago in the middle of the night when i was driving back from work and i was going to take it to get looked at in the morning but it was gone in the morning...(wtf?)..
ANYWAYS so i have been pondering this for the past few days now, and if i do have a voltage problem wouldnt the first culprit to look at be the alternator? if thats the case, is there any type of high performance alternator i could put on my truck that would been more steady voltages through my truck?
this issue also raises another concern in my head. i have been having intermittent issues with my door speakers and i was thinking if there is voltage issues that could be 1 reason why my speakers have been giving low volume/fuzziness
sorry i know its a lot of info and i jump around alot to diff issues but i have been having issues with my truck and i just want to zero in on the problem and get it fixed.
Old Oct 2, 2011 | 06:55 PM
master tech's Avatar
master tech
Site Moderator & Tech
Do you know if you have 4 wheel ABS or Rwal ABS system? And was the code U1414 or U1415?
Old Oct 2, 2011 | 09:11 PM
gjmoran's Avatar
gjmoran
im not sure, i only have disc on the front and drum in the back
Old Oct 2, 2011 | 09:12 PM
gjmoran's Avatar
gjmoran
nvm found my build sheet
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
Old Oct 2, 2011 | 11:38 PM
master tech
If you have just Rwal, which is rear ABS only. The sensor is located on the rear diff assy. It would help if you had the codes.
