Engine Oil Pressure
Old Oct 3, 2011 | 08:07 PM
MitsuRaider's Avatar
MitsuRaider
Default Engine Oil Pressure
Has anybody measured oil pressure on their 4.7?
Idle? WOT?
I have no oil pressure gauge..shame
Thanks!
Old Oct 3, 2011 | 08:55 PM
Dakkkota's Avatar
Dakkkota
cold it should be around 60...and idle hot around 20 and wot 60-100psi range i think?!?
Old Oct 3, 2011 | 09:41 PM
Hahns5.2's Avatar
Hahns5.2
Yeah probably around there^. With your turbo it will be less, as pressure=resistance to flow. Running oil to the turbo reduces the resistance to flow so pressure drops. I lost about 10PSI all around.
Old Oct 3, 2011 | 10:04 PM
Dakkkota's Avatar
Dakkkota
less than 18-20 psi hot idle may dammage engine!!!
Old Oct 3, 2011 | 11:34 PM
remme's Avatar
remme
Just measured mine, I was at 56 psi at warm up idle
Old Oct 4, 2011 | 07:34 AM
MitsuRaider
Thanks guys. Remme, what is the highest it goes under aceleration?
Old Oct 4, 2011 | 11:26 PM
remme's Avatar
remme
not sure, its a gauge in the engine bay. im dealing with vaccum leak issues now, just got 0171/0174 codes.....f*cking truck
Old Oct 5, 2011 | 12:30 AM
Mahadigus's Avatar
Mahadigus
Oil pressure on the 4.7l can safely see as low as 5psi at warm idle the low oil pressure light will not come on until it drops below 5 psi
