stock fuel system psi questions
Old Oct 5, 2011 | 02:55 PM
sullysdetailing's Avatar
sullysdetailing
Exclamation stock fuel system psi questions
hey guys, does anyone know what psi the fuel system normally runs at on the v6? also what is the stock psi for the fuel pump as well.
Old Oct 5, 2011 | 03:16 PM
QuadDodge02's Avatar
QuadDodge02
I would give airram a call. They offer different psi injectors for the 3.7. They would know
Old Oct 5, 2011 | 03:48 PM
MitsuRaider's Avatar
MitsuRaider
Hmm cant help you there, but c'mon give us an update already!
Old Oct 5, 2011 | 03:49 PM
sullysdetailing
FPR sets fuel pressure, injectors have nothing to do with it. They differ in flow rate, not PSI.
Old Oct 5, 2011 | 03:54 PM
MitsuRaider
You should probably go with a Walbro 255 fuel pump, they are fairly inexpensive and regardless of w.e PSI your stock fuel pump is pushing, more than likely it won't be enough for the new set-up, specially if you go with forced induction down the road.
Old Oct 5, 2011 | 08:35 PM
Hahns5.2's Avatar
Hahns5.2
Remme reported 56psi.
Old Oct 5, 2011 | 08:48 PM
sullysdetailing
5.3L LSx
228/228 .588/.588 114 LSA
Shortie Headers
MSD Wires
Comp Cam Push Roads and Springs
LS1 Intake Manifold
LS1 Ported TB
LS1 Fuel Rails
LS1 Fuel Injectors
Built 4l60e
Solid Motor Mounts
