led map/dome lights
Old May 13, 2012 | 08:51 AM
  #51
Originally Posted by Reject
My floor accent lights work great, they also dim with the dash lights, Same goes for my HVAC LED's.
I tied my Floor lights into the Light above my cup holders. So they are always on when the marker/HL are on. Its just they way I wanted them.
That's a great idea! I have mine tied into the dome lamp but I like the idea of a little under dash lighting all the time. Which lights did you use for that? The ones I have under there now (12 LED Blue) would be too bright to have for accent lighting.
Old May 13, 2012 | 08:43 PM
  #52
Reject's Avatar
Reject
Mine are pretty bright, but I dont find them distracting at all anymore, or to much when I put them in.
I bought them off Ebay, They are the FLAT LED Strips, not sure how many it is. The Pass. side has a nice place for it to stick to and face directly down to.
I used to have some other LED stripe ones in my 2k Dak, But I found they where hard to get pointing in a direction. These ones work great, drivers side takes a little trickery. I might make a flat bracket to stick them to.
Like these ones
http://www.ebay.ca/itm/Blue-12V-30cm...item4165c6658c
Old May 13, 2012 | 09:47 PM
  #53
yeah, the passenger side is easy on the bottom edge of the glove box, on the driver side, I had to get creative...I should take a pic, but I used velcro to attach the light strip to the bottom of the dash and a part if the steering shaft,
Old May 13, 2012 | 11:58 PM
  #54
06Dak4.7Silver's Avatar
06Dak4.7Silver
I used zip ties on both sides for mine
Old Feb 19, 2013 | 05:34 PM
  #55
GhostZero1987's Avatar
GhostZero1987
For GP which lights is which dome lights in the back of a quad cab, ovehead consoles r the the two over driver and passenger and reading one is that the little one under the ac controls? just making sure?? and how do i remove them with a flathead screw driver??
Old Feb 19, 2013 | 06:19 PM
  #56
I have no idea what you are talking about....
Old Feb 19, 2013 | 06:40 PM
  #57
GhostZero1987
for the bulbs the dome light bulb is inside the very rear inside next to rear window and the two light above the mirror above the driver and and passenger are overhead console lights how do i remove cover from those??
Old Feb 19, 2013 | 06:58 PM
  #58
Iirc, the one in the back can be pried out with a small screwdriver. If you have an overhead console, there is one screw in the front next to the windshield that has to come out, phillips head I believe and then the console pulls out towards the rear of the truck. Proper punctuations and grammar would make it easier to understand your question.
