led map/dome lights
My front ones work if I push them to turn them on.... 90% of the time lol
They also all usually stay slightly dim when the trucks on, they dont turn off fully.
I figured, That little bit keeps the very dim. and that the normal bulbs its to low to do anything.
My LED's do not illuminate at all at night, meaning when they're not supposed to. (By any chance are you guys using 99 cent Ebay lights?)
The only thing that I find odd with these lights is that once you turn the truck off, you can't turn on the map lights by clicking the light lens. I can turn them on by using the interior lights switch on the dash though. Maybe that's how they always operated though, never really took notice of it.
Other than that, the lights work as they always did with the stock lights.
But mine work fine if I click the lenses with the truck on, or off most of the time, sometimes they dont when its off.
But they are ebay lol, I dont think they have a resistor, or one thats to low.
My floor accent lights work great, they also dim with the dash lights, Same goes for my HVAC LED's.
I tied my Floor lights into the Light above my cup holders. So they are always on when the marker/HL are on. Its just they way I wanted them.
I found a place that sells the LED I put in my truck and my mothers Corolla (6 led ones) cheap.
Seller also has WHITE ones to. They are 42mm Festoon 8 LED Tube ones.
My 05 Club Cab ST has these in all 3 Spots, Both Maps and the Rear.
You can also get 168/194 Bulbs for your license plate.
Blue 8 LED 42mm Festoon : $0.99
http://www.ebay.ca/itm/Car-Interior-...item2312965821
White 8 LED 42mm Festoon : $0.99
http://www.ebay.ca/itm/DOME-8-LED-CA...item2311228c5f
Just found them today, Cheap figured others would like to know. When I got mine I bought a few extra to make sure down the road I had them.
yes sir, reverse polarity should do the trick. as long as they ground there is no excuse to not work
Works I don't know why I didn't think about turning them around earlier. the only thing is they don't work with the push on but I about never use that in the rear. So now I have to get some LEDs for the front dome lights. Good news is they work in my wife's jeep too.
