Stupid bolts on tow hooks
Old Aug 5, 2018 | 08:00 PM
Clay Anderson's Avatar
Clay Anderson
Default Use a chain adjustable vicegrip
Originally Posted by dbilik
I own a 2nd gen dakota, but decided to offer help to my friend to install a bull bar on his 3rd gen truck. I started trying to remove the long bolts that go through the existing tow hook and got stuck. They just keep spinning and keep spinning the rubber bushing on top. I am tempted to just cut the off and replace them with a thru bolt afterwards. Is this ok to do? Or does that rubber bushing on top serve some grand purpose?
If I cut the head of the bolt I can probably still remove it from the bushing once I pull it out and replace it if need be.
Hopefully I am looking at this right, but to me it seems this bolt is a body bolt and is needed, but I can replace it if need be.
I used a chain adjustable pair of vicegrips clamped around the base of the upper bushing. Remove bumper first. Worked well! You do have to fight the factory locktight the whole way. Cheater bar required.
Old Aug 6, 2018 | 07:13 AM
Seven year old thread???
Old Aug 6, 2018 | 08:16 AM
Lolol
Old Aug 6, 2018 | 09:24 AM
ZEN357's Avatar
ZEN357
I would just go to a hardware store and get some grade 8 bolts to replaced the damaged ones, put some anti-sieve on them to keep them from rusting in case you need to take it apart again.
Old Aug 9, 2018 | 04:56 AM
philipat's Avatar
philipat
I looked. Hardware store, McMaster, etc don't have anything that long. You have to get them from a parts vendor.
This is an old thread. But, it was helpful when I added my tow hooks a year ago.
Old Aug 9, 2018 | 07:23 AM
Lowes has grade 8 bolts longer than my arm......
Old Aug 15, 2018 | 02:51 PM
Seventime's Avatar
Seventime
Hey. Speaking of front tow hooks, anyone know where I could order some online? Sure would be nice having them during ice fishing/hunting season.
Old Aug 15, 2018 | 03:17 PM
ebay.
Old Aug 15, 2018 | 03:56 PM
Seventime's Avatar
Seventime
No luck there.
Old Aug 15, 2018 | 05:27 PM
Google search turned up this.
