h.o. cams
Old 11-12-2011 | 01:23 PM
remme's Avatar
remme
Default h.o. cams
benefits? Gains? What would you pay?
Old 11-12-2011 | 02:55 PM
10-15 hp., $250-$300 to buy, $1000 to install...smiles from being able to say you have ho cams, priceless
Old 11-12-2011 | 03:15 PM
Cuban11182's Avatar
Cuban11182
Problem is I can't find any right now...
Old 11-12-2011 | 04:43 PM
remme's Avatar
remme
So theyre worth it?
Old 11-12-2011 | 06:15 PM
Dakkkota's Avatar
Dakkkota
i am curious if there is anyone using lash cap with stock cam...and a homemade porting job??? i am sure this is the best bang for the buck. My car has a cam and i ported the heads my self and i have 367whp on a stock base 350.
Old 11-12-2011 | 07:27 PM
thunder98110's Avatar
thunder98110
25-30hp to the tire gains with mods. yes its worth it. best instant hp mod you can do for the 4.7.
Old 11-12-2011 | 11:17 PM
thanks winston, I figured my hp numbers were low...now, do you also need an sct to get that many ponies?
Old 11-13-2011 | 12:04 AM
thunder98110
s.c or sct is a must with ho cams. I ran 2 weeks on the stock pcm, i went with sct and blew me away, s.c will give you similar gains over the stock pcm with ho cams.
and why i say a must, you dont NEED to have a tuner, but to unleash the power yes. the motor will run fine w.o a tune.
click my HO CAMS info in my sig for more info and videos
Old 11-14-2011 | 04:06 PM
remme's Avatar
remme
How about Ho valve springs? Would there be any gains there over stock? Combined w Ho cams?
Old 11-14-2011 | 06:07 PM
Dakkkota's Avatar
Dakkkota
people use comp cams springs for some ford engine dont know witch one plz some one help here!!
