Transmission/differential fluid change question
Old Nov 30, 2011 | 03:26 PM
Hokie John's Avatar
Hokie John
Default Transmission/differential fluid change question
Well I recently purchased a 2007 Dodge Dakota SLT 4x4 V6, and I'm pretty excited. It's a clean single owner truck, 70k mils, and the carfax seems like it had regular dealer performed maintenance. However, since the truck is new to me, I'd like to change out all the lube fluids so I have a new baseline for a maintenance schedule, and so I can switch over to Amsoil lubes all at once.
I've been lurking on the site for a day or so, collecting some initial intel, but I still have a couple questions.
A) All 3rd Gen Automatic V6 Dakotas have the 42RLE transmission, right?
B) Will a 2.5Gal jug of amsoil universal ATF be enough for a FULL fluid change in both the 42RLE trans and the transfer case? Numbers for trans fluid capacities seem to be inconsistent.
C) Is there a way I could remove/drain ALL of the old trans fluid (i.e. not just pulling the pan) myself without a ton of specialized equipment or hassle?
D) I consider myself a competent shade-tree mechanic, but I have never really worked on automatic transmissions, so they kind of scare me. If I chicken out and decide to go to a shop for a trans flush/refill, how much should I expect them to charge for the service, if I provide the ATF and filter kit? How can I make sure they are using a low pressure machine that uses the trans pump to move the fluid? Is that the typical type of trans flush machine? I only want to completely replace all the fluid, I don't want any kind of weird solvents or higher-than-nominal pressures involved.
E) Does the mopar transmission filter kit come with the flat filter, screw on filter, AND filter seal?
Thanks in advance for any advice/insight.
Old Nov 30, 2011 | 04:13 PM
thunder98110's Avatar
thunder98110
D: i payed the local dodge dealer 180 to drop the pan and replace both filters and fluid.
Old Nov 30, 2011 | 05:04 PM
Hokie John's Avatar
Hokie John
Did that cost include the cost of filter and fluids, or did you supply them yourself?
Old Nov 30, 2011 | 05:23 PM
thunder98110
the dealer supplied everything.
Old Dec 1, 2011 | 12:42 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
This should be right, its the 4 speed auto
2.5 Gal is more than enough. The trans should only take 4qts for a servicing. The transfer case depending on which one you have shouldnt take more than 2.85 pints and as little as 2.5 pints depending on which one you have.
There is no easier way than popping the pan off unless you install a plug which you need to initially take the pan off. For just a fluid change all you should need is a couple wrenches and or ratchet and sockets and you can have the pan off in no time.
Thunder answered that
I am pretty sure it comes with everything
Here is my input. I hope it helps. If you need any numbers or anything I have a full Service Manual
Old Dec 3, 2011 | 02:08 PM
EliteTempleton's Avatar
EliteTempleton
Post
Yes, from what I can tell this is true.
You can get your build sheet and know for sure though, & it's free!
You can go the web form route or send a PM to DodgeCares with your VIN and he can hook you up.
