Personalizing/mods. Finally making it MY truck.
Old Feb 11, 2012 | 03:06 AM
  #71
FrenicX's Avatar
FrenicX
Not going to be able to do anything this weekend, but I did get the rear shocks on. Beltech 2212DDs. So far, I can say these are quite a stiff shock. Perhaps they need to be worn in, but they feel over dampened. I don't mind, it's much better than the free movement I got from the KYB that were on there, these are almost an inch thicker too. Beefy shocks, I like them a lot. Only for lowering though :P
There is a small concern, the bolt hole is bigger than other model specific shocks. I doubt it will be a problem, but that's probably why it doesn't show our trucks in the application list.
Old Feb 11, 2012 | 10:48 AM
  #72
varnerhba's Avatar
varnerhba
alot of times these companys are too lazy to find out if an older or other part number would fit a newer application, they leave it up to us DIY'er
Old Mar 10, 2012 | 02:40 AM
  #73
FrenicX's Avatar
FrenicX
Ok, I finally got started on this, in progress in my driveway is a truck with no front end lol.
To recap, I am installing the rotors, pads, struts, sway arm links, and I am cutting the coil for a 1.5 to 2" drop, then an alignment. At least, that was the plan.
Cracked into it today, took caliper off (easy) and spun the rotor.. only to hear a nice "crunchy" sound in the hub bearing, I don't like crunchy sounds so I hammered off the rotor (oh man what a PITA) and the crunch was still there so I ordered a hub assembly.
I started removing the hub, and got two bolts off and snapped the 3rd... damnit. Ordered 2 just in case, and now I can't get the hub off the knuckle, it's rust welded real good.
I popped the upper ball joint and it seems good, but I was able to lift the spindle up a millimeter so I need a lower balljoint... order that.
Then came the strut.. omfg the strut... I should have used air tools. I may have ruin my lower C-arm trying to get that bolt out of the bushing. So guess what? I went an bought a 25g air compressor and some air tools YAH. If I can't get the bolt out the way it is now (used a cut-off wheel in anger to get the strut out of the way) then I have a cart ready at autopartswarehouse to overnight me an arm monday...
So it was late, couldn't make much more noise so I just set-up the compressor and tools and then loosened all the stuff on the other side without popping any joints, and would you imagine.. the 3 hub bolts and 2 caliper bolts on the drivers side came off perfectly. In the morning I will see if the rotor and hub (also bad, slightly loose) will be as nice as their bolts were.
I always go in twos, so on top of the planned stuff, I will now be doing 2 hubs, 2 lower ball joints (maybe a passenger control arm and driver side balljoint)
I'm half tempted to just do the full lower arms and two new uppers just for the hell of it, then I will have a whole new freakin front end minus tierods.
anyways, wish me luck! (ps, i have pictures to post tomorrow)
Old Mar 22, 2012 | 02:43 AM
  #74
FrenicX's Avatar
FrenicX
Ok it's a little past "tomorrow" but here's the progress and finished product of all the blood, sweat, and tears that went into this cosmetic/repair build. There would have been more, and better pics but through all the frustration I think if I had picked up the camera, I would have cut it in half with my angle grinder.
Before I knew what I was in for.
After spring cut
How much I cut off
oooops...
How I modified my bumpstop to limit travel a bit, works very well. Cut this rubber stopper in half, inserted it between the stock bumpstop and the strut mount. rtv'd them in.
Taking a break....
Triumph!
Finished.
Old Mar 22, 2012 | 03:45 AM
  #75
varnerhba's Avatar
varnerhba
good work
Old Mar 22, 2012 | 06:39 AM
  #76
Dragon05's Avatar
Dragon05
good job, looks great.
