Drivers side tail light bulb keeps going out
Old Dec 19, 2011 | 11:12 AM
08_Dakota's Avatar
08_Dakota
Default Drivers side tail light bulb keeps going out
Hey everyone,
I have some sort of intermittent issue with the drivers side tail light bulb burning out quite quickly. I had the issue a few months back where the signal portion of the light went out. I replaced the bulb and all was fine. Then last night for some certain reason, now the tail light on the same side is out. All rest of it works. Signal and brake works fine. Could this be a bad bulb or some wiring issue? Any thoughts
Old Dec 19, 2011 | 03:23 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
Pick up a digital multimeter if you don't have one already and measure the voltage on each wire from the harness, except ground. Make sure you have directionals on when checking the sidemarkers and the truck in reverse gear when checking the backup lights. I don't know if this helps or not because I'm not sure if you are a DIY kind of guy or even a technician so don't get mad at me -_- haha
Old Dec 19, 2011 | 06:29 PM
08_Dakota's Avatar
08_Dakota
Thanks for the ideas. I am getting into the DIY, not afraid to try things. I was able to take the cover off and actually determined that the wiring harness which has threads into the white panel, was hanging loose. It appeared to work its way loose., once I tightened that it seems to be working. Was not a bulb after all. Looks like loose connection.
This site is great
Old Dec 19, 2011 | 09:14 PM
06Dak4.7Silver
Take a zip tie and use it to make the connection more secure. Don't overtighten it though because it could snap the clip. Best of luck, electrical problems are a pain! If the bulb isn't burnt out or damaged then you ll know its almost always the power source that is the problem
