Transmission Fluid Success
Old Jan 6, 2012 | 12:01 PM
djsilver's Avatar
djsilver
Originally Posted by rapta619
I too want to do this with my 05. Only I want to get everything out of the lines, from the cooler to the torque converter. Any ideas or suggestions?
The normal oil change only changes about 1/2 the fluid but I do mine every 30k miles so I feel like it averages out. If you want it all changed, take it to a place that can perform a "hot oil flush" They disconnect one of the lines and connect it to a machine that can flush the entire transmission and torque converter. It's a good thing to do if you've overheated the transmission by towing, or the fluid looks/smells burnt for any reason.
Old Jan 6, 2012 | 12:04 PM
SmackGoneWild's Avatar
SmackGoneWild
Yea exactly, ive always thought the 4.7 just stock had a good sound, opening that up a little more im ok with, as long as it never resembled a freakin honda im good.
jkeaton - I see your point on the setup there, pipes are pipes right? .. add in an intake with that and best guess, what would you say im really lookin at pros/cons of it?
Old Jan 7, 2012 | 02:11 PM
rapta619's Avatar
rapta619
kinda what i was thinking. i do tow alot in the summer, so this is probably my best bet. i know some places filter and recycle the same fluid, im way to sketchy on that. id rather replace it all with some royal purple and be done with it.
BTW, my flow master was awsome with the stock intake, but man oh man *makes the Tim Allen obnoxious grunt* after my k&n CAI i cream my pants every time i hit the gas.
the day after i bought the truck i had the flowmaster put on and both resinators and muffler taken off. passes NYS inspection, so im good. sounds awsome when im pulling the race car lol
