Exhaust Kit
Old Jan 23, 2012 | 07:57 PM
varnerhba's Avatar
varnerhba
the lest exhaust, the lest rust hah
Old Jan 23, 2012 | 09:35 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Originally Posted by rengnath
MBRP makes an awesome exhaust! I did the t304 kit, and other than having to loosen the clamps and adjust it a little after 1000 miles or so (the pipes must have warped a little with the heat), Ive never had to touch it again. Fits perfect, and sounds awesome.
I've been eyeing the T409 kit
Originally Posted by Backwoods18
Billy, I just commented on your FB status. My good friend growing up moved down your way, (harrisburg (sp?)) he took his chevy to Murphy's Automotive for a complete and custom Magnaflow, they do flowmaster too. Hope this helps man...
Yeah thx man. Calling them tomorrow to check em out. It was a huge help.
My one buddy might hook me up too as you can see
Originally Posted by ericemery
Billy, just get on Summit and buy yourself a nice muffler, and have a shop weld it in. they are quoting you an entire system. you dont need an entire system. you just need to cut out the spot with the hole and have it replaced.
I would go with borla if it was me.
Eric you know my options and your roll. I actually have another Pro muffler sitting in the backseat...
Originally Posted by thunder98110
just dump it under the cab with a spintech cat and a dynomax racebullet. thats what i did anyways
That's a possibility just dumping my current setup at the axle
Originally Posted by FrenicX
Where is your rust anyways? I have a repair to make before the Y-pipe on the drivers side pipe, water flows to this point and drips off and that's where the rust is, kind like what happens to the oil-pan.
It was in front of the rear wheel at the hanger
Originally Posted by Dakkkota
i have dynomax over axles tailpipes with dual in dual out muffler with custom aluminized steel front...no rust yet on exhaust..some on muffler.
I thought about that setup with my pro, but I am leaning forwards the single out style
Thx for all input guys.
Old Jan 23, 2012 | 10:06 PM
Altair's Avatar
Altair
Dak attack!
Throw in another vote for MBRP, still loving mine.
Old Jan 23, 2012 | 11:55 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
If your hole is where the hanger was welded to the pipe then just align the hanger back over the hole, put some of the exhaust glue/cement on it, and then use an angled clamp to hold the hanger onto the pipe. I don't know if this is your situation or if what I just said makes any sense to you guys but..I had a hole right after the muffler because my hanger snapped off of the pipe. Patched it up as I just described and I no longer have a leak or a dancing tailpipe
Old Jan 24, 2012 | 04:48 AM
Backwoods18's Avatar
Backwoods18
No problem. Good luck in what ever you do. Can't wait to see the outcome
Old Jan 24, 2012 | 10:11 AM
lghtngblt02
haha I figured... I am hesitant about it being loud enough. I love the sound of my Pro.
Yeah thats the issue, I may just replace a section, get a different hanger, and run this exhaust till its totally beat then move to a kit.
Yeah I am think I may to run this exhaust into the ground... literally
Old Jan 25, 2012 | 07:38 PM
lghtngblt02
SOOOO, last night I went into repair mode, which lasted all of 5 minutes before I was shutdown... in the process of reattching a hanger, I noticed a very bad issue. Remember the "crack" I thought was just porosity in a weld (from my failed inspection thread)? Yeah! I found it last night, only it had grown nearly 100 times its original length. The crack is through the muffler housing surrounding the outlet pipe... the pro muffler is pretty much junk at this point and the crack isnt worth the hassle in fixing. I didnt fix the hole in the piping nor the crack lastnight. This setup is two far gone IMO. I returned the $30 bucks worth of repair ammunition and the new Pro Series Muffler, I have a better idea... and you all are going to have to wait and see what I do!
Old Jan 25, 2012 | 08:34 PM
rengnath's Avatar
rengnath
I say you do open headers!
Old Jan 25, 2012 | 09:44 PM
lghtngblt02
Cutouts, may have been ordered...
Old Jan 26, 2012 | 05:08 AM
Backwoods18
"So sick" "what did you say??" "I said SO SICK!!" ha ha. Really, I can't wait to see what you're doing lol
