lights
Old Feb 4, 2012 | 02:34 PM
norma jean's Avatar
norma jean
Default lights
im in the market for lights and i have some questions, i have a pair of hella 500s, can i swap those out for the upgraded 100w lights bulbs in them? or will i have a problem with melting because of the difference in output intensity?
http://www.discountfleetsupply.com/helh83135312.html
Old Feb 4, 2012 | 03:06 PM
dakotaff's Avatar
dakotaff
You could overheat the wires and cause a fire, melt some part of the housing, or you could be okay doing it. Especially leaving them on for a while. I have 55 watt bulbs in my PIAA's, and never even considered swapping them for a higher wattage bulb. I definitely wouldn't do it, it's not worth the risk..
Old Feb 4, 2012 | 03:57 PM
ODXBeef's Avatar
ODXBeef
You could always convert your hella's to HID. I have a set of 700's that have 55w 5000k HID's in them and they are beyond bright.
Old Feb 4, 2012 | 04:11 PM
norma jean's Avatar
norma jean
i first read this when i got out of the gym and skimmed it and i was like pissed because i didnt think there was a solid answer. but then i actually read it, and saw the ending, thanks for the answer you have definitely steered me away from it.
this is a very good idea, slight problem, i have no idea on how to do that
Old Feb 4, 2012 | 06:28 PM
ODXBeef's Avatar
ODXBeef
Just need a drill bit, dremel, and maybe some epoxy.
http://www.clubfrontier.org/forums/f...version-69647/
Old Feb 5, 2012 | 11:09 AM
norma jean's Avatar
norma jean
the lighting difference is quite intense, but only having two wouldnt fill out my new bull bar, and theres no place to hide the ballasts, and it would be 170 to buy new lights and the hid kit. This has opened my eyes to buying hid lighting. I think im going to buy the hella 700ff. So itll be the two huge 700ffs then hella 500s then the fog lights.
Old Feb 5, 2012 | 11:15 AM
varnerhba's Avatar
varnerhba
they sell hella hid conversion kits....
Old Feb 5, 2012 | 11:50 AM
ODXBeef's Avatar
ODXBeef
I'd be curious to see that. Because you have to drill out the housing no matter what so a "kit" beyond just buying some h3 hid's would be rather pointless.
Old Feb 5, 2012 | 01:08 PM
dakotaff's Avatar
dakotaff
If your obsessed with HID driving lights, just get some HID driving lights. They aren't cheap, but here's a set of KC's for half price.
At least they'll be in a proper housing and distribute the light correctly.
KC HID's
Old Feb 5, 2012 | 02:24 PM
norma jean's Avatar
norma jean
KC HID's
I almost sh*t my pants when I saw that price, I could buy a body lift for that price
