left turn signal
Old Feb 7, 2012 | 08:01 PM
norma jean's Avatar
norma jean
Default left turn signal
I have been dealing with this problem for years, I hit the left turn signal and it flashes the right turn signal, but if I hit the right turn signal its fine. This doesnt happen all the time, but often enough, its like it has a mind of its own!!
anyone else with this problem? anyone fix this problem?
Old Feb 7, 2012 | 08:08 PM
06whitedak's Avatar
06whitedak
yeah i have the same issue. however when it happens just tap on the top of the steering colum and it will go back to normal. its the multi-function switch going bad.
Old Feb 7, 2012 | 10:37 PM
norma jean's Avatar
norma jean
sounds like a very technical fix haha
Old Feb 7, 2012 | 11:12 PM
varnerhba's Avatar
varnerhba
U need a new combination switch(the whole assembley)
Old Feb 7, 2012 | 11:33 PM
norma jean's Avatar
norma jean
Pooper scoopers that sounds expensive/complicated
Old Feb 8, 2012 | 08:58 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
The hardest part maybe removing the steering wheel if that even needs to be done... I know the procedures say so, but most often, IMO they add extra steps and remove extra stuff when its not fully need, it just adds extra moving space...
Old Feb 8, 2012 | 09:00 AM
Eimer123's Avatar
Eimer123
Might get away with trying to get in there with some contact cleaner???
I have never really looked into the switch, but might just be dirty.
Old Feb 8, 2012 | 09:15 AM
norma jean's Avatar
norma jean
im a little surprised that no one has had this problem, there was a recall on this problem, i once took it in and they told me i wasnt on it
Recall ID # 5333 - VISIBILITY:WINDSHIELD WIPER/WASHER:SWITCH/WIRING Hide Details Recall Date:
FEB 09, 2006
Model Affected:
2006 Dodge Dakota
Summary:
ON CERTAIN PICKUP TRUCKS AND SPORT UTILITY VEHICLES, A STATIC ELECTRICITY SPARK BETWEEN THE OPERATOR AND THE VEHICLE CAN CAUSE THE TURN SIGNAL, HEADLAMPS OR WINDSHIELD WIPERS TO MALFUNCTION WITHOUT WARNING.
Consequences:
THIS CAN IMPAIR THE DRIVER'S VISION AND RESULT IN A CRASH.
Remedy:
DEALERS WILL RE-FLASH THE INSTRUMENT CLUSTER. THE RECALL BEGAN ON MARCH 6, 2006. OWNERS MAY CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Potential Units Affected:
79701
Notes:
DAIMLERCHRYSLER CORPORATION
Old Feb 8, 2012 | 09:26 AM
varnerhba's Avatar
varnerhba
Once a recall always a recall
