leak?
Old Feb 19, 2012 | 07:11 PM
  #21
FrenicX's Avatar
FrenicX
Originally Posted by Alfons
but still it's not very comfortable rolling around on the frozen ground & my garage is filled with tools
Some people like creepers but I too have a pretty full garage so sometimes I have no-where to roll one really. I found that if you get a couple of those heavy-duty plastic office chair pads, (for rolling chairs) like $15 a piece from costco.. they are quite slick and very easy to slide on while under the vehicle. I just wipe them down after an oil change and hang them on my wall for next time.
I'm kind of a diehard when it comes to stuff that needs to be done outside. All the auto repair stuff I've had to do has always happened in the winter months. I think I've gotten used to the frozen hands and runny nose while working lol.
for normajean, has it leaked since you wiped it down?
Old Feb 20, 2012 | 12:54 AM
  #22
varnerhba's Avatar
varnerhba
Originally Posted by norma jean
as per the running hot, I havent had that happen yet, the transmission is good, but the coolant looks low, took a picture of the reserve, i cleaned the hose and the ends, then i put a piece of cardboard under the front end and let the truck idle and reved it several times, and nothing, so i put the truck back in the garage and put the cardboard back under it. one thing i learned, is that a k&n intake is friggin loud
dude just go to pep boys and rent a cooling system pressure testure, its free and ull found out if your looking from the radiator...
Old Feb 20, 2012 | 01:40 AM
  #23
FrenicX's Avatar
FrenicX
Pressure testers do work, I've used them once or twice. First time on my Ranger, diagnosed a crack in the radiator epoxy, and second time on my S10 which diagnosed a head gasket leak.
But other than that, trans cooler lines won't be hard at all to replace if that's what it turns out to be.
Old Feb 20, 2012 | 01:21 PM
  #24
varnerhba's Avatar
varnerhba
pressure testing will diagnos a leak, unless your leaking from the outside of the block on a pressure test, the best way to diagnos a head gasket is a block test.... 2 different testing kits.
Old Feb 21, 2012 | 08:37 AM
  #25
norma jean's Avatar
norma jean
nearest pepboys is half an hour away. it has leaked little on the fastener, by a little i mean a drop that i touched and felt, it didnt feel like oil, more water based, so im gonna just replace that quick disconnect. thanks for the help guys
