What does this go to?
Old Feb 27, 2012 | 08:00 PM
Deer Hunter's Avatar
Deer Hunter
Electric Brake Kit (P/N 56045795AB)
The harness for the Electric Brake Kit connects to blue connector under the inst panel left of steering column, near top of large connector bracket.
Circuit Function: (4 wires on harness)
ground-dark green w/ black trace
brake sense input(brake lights)-lite blue w/ white trace
trlr tow elec brake feed-lite blue
+12v (30A max) batt feed-white w/red trace
I'm going to assume that all wires from the harness are to go to your dash mounted brake controller (I've only seen one and didn't look at wiring) and that it intergrates into the trlr plugs. I have a 7 pin round and a 4 pin straight line. I always assumed the 4 pin was for trlr brakes. The wire colors on back of 4 pin are not the same colors as the wires on dash harness. I'm gonna have to suggest eyeballing the owners manual or the service manual for that trlr wiring.
Old Feb 28, 2012 | 08:49 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Weird, never have noticed that wire on mine. Now I have to look...
Originally Posted by Eimer123
My guess would possible be a reverse light wire for trailers that have reverse lights. Easiest way to find out is get a wire tester and and try all your possible trailer wire options. Left/right turn signals, brakes, reverse, stuff like that to see if there is any power when any of those happen.
The 7 Pin incorporates the reverse light option on trailers. Its the center pin.
The 4 pin is lights only, left, right, park, and ground.
The 7 pin is left, right, running lights, battery, reverse lights, brakes, and ground. The brake controller connection should match with the 7 pin.
Page 262 of your owners manuals has the configuration and what each pin is.
Old Feb 28, 2012 | 11:22 AM
reagor's Avatar
reagor
maybe something for use in back up cameras or park assist systems
its the export model thatsthe hot lead for the tripod mounted electric gattling gun for use in libia
Old Aug 1, 2014 | 02:30 PM
Zombifyd's Avatar
Zombifyd
Well I was searching for a wire to splice I to for my third brake light on my new cap and I saw this wire. And I tested it out and that's exactly what its for. Just use that wire for your new third brake light.
Old Aug 1, 2014 | 02:52 PM
adamjeeps's Avatar
adamjeeps
Yep, same one I used. Much better than splicing into the brake lights.
Old Aug 5, 2014 | 11:29 PM
pyrofossil's Avatar
pyrofossil
Well... now I know before just wiring up what to me makes since (tapping into brake light wires) I should do little research. Would be a much easier and nicer install.
Old Jan 4, 2015 | 03:59 PM
Greenstezz's Avatar
Greenstezz
I'll have to see if my truck has this wire!
I've had the shell on for over a year and haven't hooked up the brake light yet....
