Messed up idle
Old Mar 14, 2012 | 07:25 PM
Originally Posted by dakota_raven
I got the same problem! Used a scan tool and no codes also!!
Glad to see you back raven.
Old Mar 14, 2012 | 08:53 PM
CrewKota's Avatar
CrewKota
Did you disconnect your battery? If so you reset your computer. This happened to me, the fix was clean your TB and IAC. As things get dirty the computer will compensate for it. When you reset the computer it will go back to stock. Good Luck!!
Old Mar 14, 2012 | 10:53 PM
rebel4055's Avatar
rebel4055
Went and cleaned the TB. Lets see what happens. Also where on here was that DIY CAI? Want to do that now.
Old Mar 14, 2012 | 11:44 PM
varnerhba's Avatar
varnerhba
do yourself a favor, go to the dealership get a IAT sensor gasket, take out the bottom sensor, wich is the idle air temp sensor and clean the f*cker too, seperatly, then go to the dealership after and have them make sure your software is upt to date.
Old Mar 15, 2012 | 01:36 AM
CanadaDak's Avatar
CanadaDak
i have a similar problem, my idle sits around 6-700 and occasionly when parked it will stall, sometimes at red lights it has a fairly bouncy idle gives the truck a good shake. hasnt stalled for a few weeks tho
Old Mar 15, 2012 | 07:42 AM
06Dak4.7Silver's Avatar
06Dak4.7Silver
Mine idles at exactly 700..used to surge up to 950 with the busted TPS but never had low idle issues
Old Mar 15, 2012 | 08:11 AM
dakota_raven's Avatar
dakota_raven
Thanks j.....it has been a long and tiring road, still dealing with my divorce but the day is almost here.....4/16/2012.....finally....
