New headlights
Old Mar 31, 2012 | 03:25 AM
marcsnyder05's Avatar
marcsnyder05
Originally Posted by CanadaDak
so heres the update, went together pretty well, took a few trys to get them to work the way i wanted it to, on my headlight connection i got the 3 wires, black-ground white/blue stripe and white/green stripe and its connected to the white and blue one so i have them working only on my low beams, driving lights and high beams the halos go off..
hooking them up to the white/green there only on with the high beams.. so im stumped on how to get it to work as long as the lights are on, it would look sweet if you could have them come on even with the parking lights so it would be just the 2 orange markers and the halos and other leds on with no light on the main bulbs, youd really be able to see the "angel eye"s.. so if anyones got any input?
as for the aim, out of the box there not to bad at all, its a pretty solid an level line up top but down low i have a black space just under the lights and the left side is a little bit farther out, decent enough for a few days till i can go out to a field at night and play with them a bit, ganna try and find some tips or how-tos on aiming your lights and see what happens.
and with only running them for 30 min maybe a bit longer quiet a bit of condensation built up at the bottom by the 5 little LEDs on the bottom and u can feel the heat the give off its definatly warm
but anyways heres the pics i love it makes a huge diffrence even makes the ****y chrome grill look better haha, but ya they look awesome at night im super stoked
The condensation will go away after a couple weeks mine had condensation too. For the halos I wired them into the running lights so they would be on anytime the lights are on. In the harness going to the blinkers/running lights there should be a white wire with a red stripe. That will be the power wire for running lights. That is the wire that I tapped into for mine. you can use any black wire for the ground I used the one for the blinkers/running lights.
Old Mar 31, 2012 | 03:55 AM
CanadaDak's Avatar
CanadaDak
are the running lights in the blinker harness cuz i used the white/blue in the headlamp harness... only white/green white/blue in headlamps didnt look at blinker wires
Old Mar 31, 2012 | 04:00 AM
marcsnyder05
Yes sorry I ment parking lights not running lights
Old Mar 31, 2012 | 07:15 AM
Dragon05's Avatar
Dragon05
yeah, mine are tied into the parking lights and the amber and two halos come on only. I'm gojng to run my 3 leds and the top bar to a separate switch and power lead.
Old Mar 31, 2012 | 09:26 AM
CanadaDak's Avatar
CanadaDak
son of a!! Ok right on ill try re wiring it after work today..
Old Apr 1, 2012 | 09:33 PM
rebel4055's Avatar
rebel4055
I love them! Can I get a link to them?
Old Apr 1, 2012 | 09:47 PM
Reject's Avatar
Reject
Search Ebay. First thing that came up when I search "05 06 07 Dakota Headlights" You can prob find cheaper tho, Mine only comes up with ones that ship to Canada lol
http://www.ebay.ca/itm/05-08-DAKOTA-...item415cbd52e6
There are afew that LOOK the same but have slight differences like, This one has 5 LED's, Others have 3, or a strip at teh top and such
Old Apr 1, 2012 | 09:53 PM
rebel4055's Avatar
rebel4055
I actually just found that one. And if you scroll down it says $0 for 48 states.
Old Apr 2, 2012 | 04:53 PM
CanadaDak's Avatar
CanadaDak
make sure there the CCFL ones tho
Old Apr 2, 2012 | 05:42 PM
FrenicX's Avatar
FrenicX
Those are sweet, now I want a set lol
