Shifting issue
Old Apr 1, 2012 | 08:17 PM
Haxzorian's Avatar
Haxzorian
Unhappy Shifting issue
I have a 2005 Dakota Quad Cab 4x4. 3.7L V6, 4 speed automatic transmission with overdrive.
I've noticed for a while now that when shifting from 1st to 2nd gear at around 1500RPM to 1700RPM the truck jerks, only once, but violently. Then continues running normally. Shifting from 2nd gear on up to 4th without issue. I added some transmission fluid just to see if it could be a low fluid issue. That seemed to help but almost in a placebo way. I'm a novice when it comes to more complex workings of vehicles in general.
Any ideas what I could look at or what I should look out for when I take it to a transmission shop?
Old Apr 3, 2012 | 08:29 AM
Barkleyfan's Avatar
Barkleyfan
First thing they will look for is excessive metal particles in the pan, indicating mechanical issues. If you do go to a shop, insist they use Mopar ATF, not generic with conditioner. Dodge transmissions don't like generic fluid.
These transmissions have a special kickdown that is different than standard second gear shift pattern. Could be a simple solenoid issue, but I don't pretend to be an expert, just throwing out ideas.
