Strange Idle
Old Apr 9, 2012 | 09:48 PM
RedTorpedo's Avatar
RedTorpedo
Default Strange Idle
So today I got in the truck to come home and like always I start the truck and wait for the idle to come down to normal. Nothing strange has happened until today, when I started the truck it revved several time on it's own before returning to it's normal starting procedure and idle. Has this happened to anyone else? Should I be concerned?
Old Apr 9, 2012 | 10:38 PM
Eimer123's Avatar
Eimer123
Happens to a lot of people. Its called time to take the carb off clean the snot out of it, and the sensors.
Simple to do, just be careful with the sensors.
Old Apr 9, 2012 | 11:24 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
Clean your Throttle Position Sensor and if that fixes the surging then replace that sensor. I had that exact issue..does it do it when you put it into park as well? The butterfly valve on my throttle body was actually free of any carbon buildup to my surprise. But the TPS...it has been a problem for a lot of us on here
Old Apr 10, 2012 | 07:17 AM
RedTorpedo's Avatar
RedTorpedo
Well I've only had the truck for two weeks, but in that time this is the only instance of this happening. Thanks for the info though guys. Luckily it's still under warranty from the dealer, so I'm going to make them do the work.
