Dead Power Window/s
Old May 5, 2012 | 01:44 AM
Growlor's Avatar
Growlor
I recently had the dealer fix my passenger side for the 3rd or fourth time. They do some kind of lube as a temp fix and then ordered another part (not sure but think it was rails) for long term fix.
Old May 5, 2012 | 06:10 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Well, today I have speed... its gotta be a lube issue. Its pretty warm today.
Old May 6, 2012 | 05:34 AM
Deer Hunter's Avatar
Deer Hunter
It was a long time ago, but if I remember correctly, when I joined DF in mid 06 there was already a TSB out for the 05+ power windows being super slow and I'm pretty sure Dodge was replacing the regulators with a new style reg.
Old May 6, 2012 | 10:35 AM
Someone's gotta say it.....
thats what she said...
Old May 6, 2012 | 03:09 PM
gjmoran's Avatar
gjmoran
ive heard of people using aftermarket motors and not having good results...failures/etc very soon after replacing.
Old May 8, 2012 | 09:43 AM
superdak05's Avatar
superdak05
I replaced both of my window units, 55.00 for each assembly, super easy to do
Old May 8, 2012 | 06:01 PM
Deer Hunter
Did it make a differance? If so, what brand or retailer did you get them from?
Old May 8, 2012 | 08:18 PM
Growlor's Avatar
Growlor
Not sure why, but I just had a vision of a Tim Taylor (from Home Improvement) type mod for this ("more power!") http://www.robotmarketplace.com/prod...MS-PMG132.html
THAT ought to have enough torque to solve the issue! :P
Old May 8, 2012 | 10:27 PM
mercury89's Avatar
mercury89
I had a similar problem with a 2001 Nissan Xterra. Different truck obviously but the fix may be the same. Window was really slow and labored and then one day stopped. Lubed the track and new regulator and it was as good as new.
Old May 9, 2012 | 12:57 AM
FrenicX's Avatar
FrenicX
Haha, I was thinking something similar.
When I bought my truck, both sides actually had the rails "loose" inside, so the windows would actually swing and hit the inside of the door shell when I shut the door with them rolled down. So they were replaced and lubed then... brand new slides and fresh lube.
A year later, the passenger side is slower than a snail turd.
