water-methane injection
Old May 3, 2012 | 10:24 AM
Designer's Avatar
Designer
Default water-methane injection
http://www.snowperformance.net/index.php
anyone ever look into this?
Old May 3, 2012 | 10:54 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Nope, I do know a handful of people whom have the setup on Turbo and or Supercharged Setups though...
Old May 3, 2012 | 12:21 PM
thunder98110's Avatar
thunder98110
for boost yes, if you are N/A, not worth it. I talked to hemifever about it and he said that for the 4.7 there is only so much your can advance and see a gain in HP, the methanol wont do anything other than keep the engine clean, for N/A that is.
hemifevers email:
The timing that these run already won't give you but a few more hp getting more aggressive. Advanced timing doesn't always mean more power with every config. Cams and heads will generally respond to more timing before a stock engine would. but no, I don't have any body messing with meth injection to get more timing on stock n/a engines. It makes a ton of difference on diesels but some folks have done it and not gotten rave results.
