replacing electriical outlet/cigarette outlet in dodge dakota 2005
Old Aug 22, 2024 | 09:58 AM
MAXDODGE999's Avatar
MAXDODGE999
Default Lighter
Originally Posted by jkeaton
Why do you want ot replace it? You dont state it is not working, only that replacing the fuse "did not work". Did not work for what? If the outlet it is not working how are you determining this? Do you have a meter to check it with or are you just plugging something into it and whatever you are plugging in does not work? There is a fuse that has two positions that make the outlet always on or only on when the truck is running, have you tried to power whatever it is your plugging in to it with the truck running also? A little more info would help narrow this down.
LIGHTER NO WORK.i dont find fuse is not identification for lighter.Thank YOU
Old Aug 22, 2024 | 10:34 AM
This thread is from 2012. You're better off starting your own thread in the appropriate section. If you have a 3rd gen Dakota, then read through this thread. Otherwise, start a new one.
