Ignition Idle Air Control Valve AC482 O ring
Old May 18, 2012 | 07:55 PM
mytrplseven's Avatar
mytrplseven
Default Ignition Idle Air Control Valve AC482 O ring
Anyone know where I can find replacement small O ring for the Ignition Air Control Valve? I don't want to pay over $50 for a valve that works fine just to replace a broken O ring. If you don't know a resource, the dimensions could be helpful. The small one was broken and the idle stability sucked.!
Old May 18, 2012 | 08:01 PM
Do you mean the idle air control?
Old May 18, 2012 | 08:25 PM
FrenicX's Avatar
FrenicX
I'll get you the dimensions, or as close to as I can. There's two O-rings by the way, which do you need? Inner or outer?
edit, oh the small one. nvm.
Old May 18, 2012 | 08:39 PM
FrenicX's Avatar
FrenicX
25.5mm OD
21mm ID
2.3mm thick
That's the best measurements I could do with a dental lab tech's caliper.
Old May 18, 2012 | 10:02 PM
mytrplseven
Default O rings dimensions
Thanks for the info, Frenick (sp). I can take that to Grainger locally and see if they can get me an O ring I can use.
Old May 18, 2012 | 10:56 PM
FrenicX's Avatar
FrenicX
no problem at all
Now I wish my name was Nick, 'cause that would make my screen name so much cooler.
