Gettin hot...Flexalite at it again to help me out
Old Jun 17, 2012 | 07:21 PM
  #31
Alfons's Avatar
Alfons
Sleds, that's a pretty clean job, I like the mounting setup. I would really recommend that you consider designing yourself a shroud to give a better distribution of the pushed air across that radiator - as it sits now, the fan has no effect on any of the rad outside of the fan housing & without ducting the air, even the whole fan radius wouldn't be effective. I've used sheet ABS to make fan shrouds, 1/2" thick for the structural portions, held together with ABS solvent and self tapping screws, then 1/8" for the flat ducting and the "ring" around the fan. All my work was done with puller fans where the shroud is easier to design, with a pusher, you need some additional ducting to funnel the air into the fan and then when the fan pushes that against the rad, it should create a bit of pressure against the radiator - this will cause the pushed air to spread across the rest of the fan, giving you a more even cooling effect across the whole rad.
Later this summer I'll be building myself a shroud adapter to mate a Ford Taurus fan to the Dakota radiator - I'm doing this to avoid making the contoured funnel part of the shroud that goes around the fan as well as the mounting ribs that hold the motor with blades.
Old Jun 18, 2012 | 07:58 PM
  #32
projektdirtfab's Avatar
projektdirtfab
a little OT but what part of town did you move to? and nothing really helps our trucks out here in the desert. i run down powerline road at about 100mph at 110 degrees ambient and it goes to about 3/4 on the temp gauge.
Old Jun 19, 2012 | 08:18 AM
  #33
mikeg87xx's Avatar
mikeg87xx
Ive got a lot of friends in the armed forces, out in new mexico, nevada etc, and a couple run 60 / 40 mix in there trucks and ive never heard any of them complain about overheating.
