day time running lights
Old Jun 18, 2012 | 09:01 PM
phoenixbird's Avatar
phoenixbird
Red face day time running lights
Hay all! I'm looking to put day time running lights on my 05. It currently has stock switch setup. Has any body done this before? Any info out there?? THANKS
Old Jun 18, 2012 | 10:06 PM
gkates's Avatar
gkates
When I first picked up my truck it had the drl's enabled. I put hid's on and it was messing with them so I took it to the dealer and they turned them off for me. Had to go into the computer and turn them off. They didnt charge me anything. Only took them about 10 min. Im sure it will be the same for turning them on. Myne came on as soon as I put the truck in gear. Id take it to the dealer and see what they can do for you. Hope this helps!
Old Jun 18, 2012 | 10:50 PM
Put you some aftermarket driving lights behind the grill, wire them to a 12 volt supply that is hot when the truck is running. Instant DRL's.
Old Jun 18, 2012 | 10:55 PM
Dragon05's Avatar
Dragon05
Could do the same to the fog lights.....
Old Jun 18, 2012 | 11:15 PM
Reject's Avatar
Reject
Or, have the dealer turn the factory DRL's on.
Factory DRLs on is Low-powered High beams.
(My sig is Factory DRLs turned on - Truck is running and in Park, They only go out when the Parking Brake is applied)
Old Jun 19, 2012 | 08:10 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
In Canada they are required, the US, not so much...
Old Jun 19, 2012 | 05:40 PM
Reject's Avatar
Reject
Yep, Even older cars are required to have them installed, technically.
