Towing. Am I good to go?
Old Jun 19, 2012 | 06:30 PM
MIke LeBlanc's Avatar
MIke LeBlanc
Default Towing. Am I good to go?
Hoping someone with knowledge can tell me if I am good to go. I have a 2006 Dakota SLT Quad Cab, factory tow package. I have a brake controller installed. 3:55 axle ratio. V8 Magnum engine. Specs say it can tow I believe 6500 LBS? And it is a rear wheel drive not 4 wheel. I have purchased a 21 foot Lite trailer. Dry weight 4160 Pounds. I doubt very much we will load it up, so lets say total weight 5000LBS. I have bought a weight distribution kit with sway bars. From all that I have read and it has been substantial, I am pretty sure it is all fine and towing this with my dakota will be a breeze? Thanks all ..Appreciate it.
Old Jun 19, 2012 | 06:39 PM
Should handle that no problem. You could make it better by installing an aux. transmission cooler.
Old Jun 19, 2012 | 07:50 PM
jasonw's Avatar
jasonw
Site Moderator
Make sure and turn that OD gear off. Running in OD with that much of a load will kill your transmission. That being said, as long as you go easy on it and regular maintenance has been performed, it should be fine.
Old Jun 19, 2012 | 07:57 PM
MIke LeBlanc
Default OD
How do you turn off the OD? I do not have an OD button anywhere on my truck. I know some of the older ones do. I had a good feeling, now my bad feeling is back.
Old Jun 19, 2012 | 08:05 PM
damyankee84's Avatar
damyankee84
On the end of your gear shifter there should be a button for the tow/haul option, that turns off the o/d
Old Jun 19, 2012 | 08:08 PM
MIke LeBlanc
Default OD
Gotcha...Lol..Drive with tow/haul button on. I do that even when I was towing the 2oooLB tent trailer. So, I will continue to do so. Thanks.
Old Jun 20, 2012 | 07:46 AM
mikeg87xx's Avatar
mikeg87xx
the transmission cooler idea cant hurt either... goodluck.
Old Jun 20, 2012 | 08:36 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Sounds like you are good to go, you are going to know its back there but that's about it. You shouldnt have any problems.
Old Jun 21, 2012 | 10:18 AM
TomZ's Avatar
TomZ
Don't wait until you're ready for a trip to learn about your controller. Learning the proper setting should be in the controller manual. Find a deserted road or big EMPTY lot to experiment. Remember, trailer tire pressure and changing trailer weight will effect controller settings.
Sounds like you're well set up. The advice to add a trans cooler is spot on. There are two types, tube and fin: inexpensive and just ok, or a plate style: more expensive but better cooling. Make sure the truck and trailer brakes and tires are 100%. The worst things that would normally happen while towing would be an inability to stop soon enough, or a blowout. Determine if the current mirror set-up enables you to see adequately. Towing makes every driveline system on the truck work harder, from rear diff lube to engine coolant. Belts and hoses need to be looked at, fluids and lubricants need to be adequate. Nothing ruins a vacation like a mechanical problem that didn't need to happen from lack of maintenance.
Old Jun 21, 2012 | 02:08 PM
Deer Hunter's Avatar
Deer Hunter
Just a side note on trailer towing. It's never a good idea to put radial tires on a trailer. The soft sidewall is what gives a trailer that sway. If anybody has ever seen someone on the highway with their trailer swaying and thought, "Holy crap, that doesn't look good." It's either radial tires or improper tire pressure. Never trust a saleperson to know whats right, it's all about the sale, not proper size or constuction.
