Stock Brakes / Rotors junk?
Old Jun 30, 2012 | 11:34 AM
sdsdsd's Avatar
sdsdsd
You said it JUNK!
Old Jun 30, 2012 | 06:16 PM
mikeg87xx's Avatar
mikeg87xx
I replaced my pads and rotors today with the drilled slotted rotors and the ceramic pads. One thing I noticed, no matter how many times I turned those bolts on the caliper, theyd turn but would not do anything else, I notced there is another bolt moving on the inside of the slider as well, do I need to hodl that in place with vice grips...for future reference? I ended up just taking the caliper bracket bolts off and that removed the whole assembly.... the rotors i needed to fight with because both were rusted on. Loving the Powerstops so far ! Also got attacked by Wasps in the porcess. My face is in pain...
Old Jun 30, 2012 | 11:43 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
yeah you need to stick a 15 mm, IIRC, open end wrench over that inner bolt in order to lock up the slides. It is annoying but obviously not difficult. did you paint your calipers????
Old Jul 1, 2012 | 12:20 AM
On our 09 Journey, the original pads were warped at 12k. Replaced under warranty by the same crap and they were warped by 30k. By then I said screw it and got some mid-grade rotors from oreilly's and they have lasted. At 59k now, no evidence of warping. Even mid-grade aftermarket stuff is better than oem. All I've done on the Dak is replace the front pads (and they really didn't need it). I bought it with 48k on it and now it has 85k.
Old Jul 1, 2012 | 08:34 AM
mikeg87xx's Avatar
mikeg87xx
I tried with vice grips, anyways ill. Pick up the iirc next time, only sizes I had were 10 8 and 12. Didn't paint the calipers yet. These powerstop pads are very smooth and silent. I notices they didn't come with hardware but fit very snug. The Rotors are great as well. Put 150 miles on them so far.
Old Jul 2, 2012 | 10:21 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
I replaced mine at 39k because of corrosion spots, I put on new brakes and rotors, autozone mid grades, so far so good. I have a slight quiver while lightly braking, but I am attributing it to the driveshaft since it was there before the brakes were replaced...
