The OFFICIAL Lift and Tire Size Thread
Old 01-03-2014, 08:41 AM
matt0901's Avatar
matt0901
matt0901 is offline
New Member
Thanks, there really isn't much I can find as far as wheels when you take that into consideration.
  #122
Old 01-05-2014, 12:50 PM
CountryBoySwag's Avatar
CountryBoySwag
CountryBoySwag is offline
I got a 2008 Dakota Ext. Cab v6 2WD and I wanna lift mine. I was thinking of a spacer lift (2.5" front and 1.5" rear for $370 installed) or should i go with suspension?
  #123
Old 01-05-2014, 10:30 PM
CountryBoySwag
I'm thinking of a spacer lift for my 2wd 3g dakota. 2.5in front and 1.5in rear.
  #124
Old 01-06-2014, 04:51 PM
dakotaff's Avatar
dakotaff
dakotaff is offline
There's plenty of wheels that fit fine, keep looking.
Go for it!
  #125
Old 01-06-2014, 05:26 PM
jkeaton is offline
Dodge Forum Administrator
Do it. Also you could install them yourself and save a ton of money. Just be aware, that even though you are 2WD, a 2.5" kit will put the tie rods and ball joints at extreme angles and could lead to premature failure.
  #126
Old 01-06-2014, 05:53 PM
dakotaff's Avatar
dakotaff
dakotaff is offline
Agree with that, a 2"/1" lift is a better option. Plus the extra 1/2 " doesn't allow for any larger of a tire.
  #127
Old 01-11-2014, 12:28 AM
Ronius_MAXimus's Avatar
Ronius_MAXimus
Ronius_MAXimus is offline
I have an 07 2wd... I am considering adding a 3" PA body lift to a rough country lift kit. Will this be doable without any issues?
  #128
Old 01-15-2014, 12:31 AM
donkeypunch's Avatar
donkeypunch
donkeypunch is offline
King Jackass
Well, plenty of members have run across "issues" with any installation of anything. Lol.
So, most members that have installed a body lift have complained of the front body mounts (that go through your tow hooks) being kind of a hoe to get out. Other than that, the only way is to go up.
  #129
Old 01-17-2014, 12:58 PM
Ronius_MAXimus
Since my mechanic was unable to put on the rough country lift, after some minor trimming, i'm on 265-70-17 Bridgestone Dueler RVT tires and stock height.
  #130
Old 01-18-2014, 12:45 AM
donkeypunch
King Jackass
Wait...your "mechanic" could not install a leveling kit? Please explain this before I call him something that will put me in "time out".
Quick Reply: The OFFICIAL Lift and Tire Size Thread
