Mark 8 Efan
Old Jul 28, 2012 | 07:57 AM
  #31
Alfons's Avatar
Alfons
Originally Posted by Holbrook.Jeremy
Can someone shed some light on how to wire a relay so it triggers when the a/c is turned on. I've checked both sides of the plug, both provide ground when the a/c is on or off. I have a feeling I'm missing something simple (I'm sure the beer isn't helping.)
There are several ways to "tap" into the A/C on/off cycle, but one sure way is to tap into the line that triggers the e-clutch for the compressor and use that voltage to enable a relay. Using this line, there should be adequate current there to just tap into it and take the new wire to your single fan control relay (this will go to pin 85 or 86, whichever one you currently have the +12 going to now). If you think you need another relay, use that new wire to activate it and wire it up to activate your fan control relay - this way, if your thermal switch isn't ON when the A/C comes on, the voltage from the A/C tapped line (or new relay) will activate the fan control relay.
If you use an additional relay between the A/C and the fan control relay, it doesn't need to be "heavy duty", it's not going to be carrying much current, only enough to activate the fan relay (probably not much more than an amp, depending on the relay).
Old Sep 3, 2012 | 11:27 AM
  #32
Holbrook.Jeremy's Avatar
Holbrook.Jeremy
This about where the needle sits no matter the outside temp. On this day it was 85 or so sitting in traffic on Rte 16 in North Conway.
Old Sep 3, 2012 | 11:43 AM
  #33
bwdakrt's Avatar
bwdakrt
^^^Nothing wrong with that. Looks to be in the 185-190* range which is great!
Old Jun 24, 2013 | 01:43 AM
  #34
FrenicX's Avatar
FrenicX
How's this setup holding up Jeremy? Did you figure out a final solution to the relay problem?
Old Jun 28, 2013 | 03:46 PM
  #35
Holbrook.Jeremy
I had installed a few 200amp relays and they were holding up fine when I sold the truck last October. It might be work looking into the dual fan setup from a 2010+ Silverado (I bought a 2012) and see if that can be fitted onto the radiator.
