Ford Injectors
Old Jul 15, 2012 | 11:51 PM
bonecollector 3's Avatar
bonecollector 3
Default Ford Injectors
Ok after reading all the hooplah about the 4.6 injectors I figured why not give the truck a little bit more power to go with the new tires and lift ive got on the way. So my questions are.....#1 how much actual power increase can I expect and #2 how hard is the install.
Old Jul 16, 2012 | 09:45 AM
superdak05's Avatar
superdak05
no really power, just a better spray pattern. simple install, relieve the pressure from the fuel system, unbolt the fuel rail and simply pull up, all 4 injectors will pop up, but after reinstalling the injectors, take a little vaseline and rub it on the new rubber o=rings then install
Old Jul 16, 2012 | 10:00 AM
Don't you have to have a tune also, or your just adding more fuel without really doing anything??
Old Jul 16, 2012 | 10:12 AM
bwdakrt's Avatar
bwdakrt
No tune is necessary and you're not adding more fuel just getting a lot better spray pattern that makes for a more complete combustion of the fuel.
Old Jul 16, 2012 | 10:18 AM
DM_kota's Avatar
DM_kota
These are the cobra ones we are talking about right?? If it is a cleaner spray pattern for a better burn does it do anything for fuel economy?? I am assuming if it does it is minimal
Old Jul 16, 2012 | 10:21 AM
bwdakrt's Avatar
bwdakrt
They don't have to be from the Cobra and as far as increased mpg goes that all depends on your right foot.
Old Jul 16, 2012 | 12:25 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
Yeah, if anything I think if you kept the same driving habit it would actually benefit fuel economy since it makes combustion easier with same fuel levels
Old Jul 16, 2012 | 04:26 PM
DM_kota's Avatar
DM_kota
I am sure this has been beaten to death, but so injectors for any 4.6L ford engine would work? even out of a junkyard crown vic that is only a few years old?
Old Jul 16, 2012 | 04:30 PM
bwdakrt's Avatar
bwdakrt
In the 3.9, 5.2 and 5.9 I'm positive they will but don't believe they will in the 4.7.
Old Jul 16, 2012 | 04:37 PM
bwdakrt's Avatar
bwdakrt
I've explained the Ford 19# fuel injectors in this thread on what will work and how to tell which injectors you need for your truck.
https://dodgeforum.com/forum/2nd-gen...anifold-2.html
