I thought we took 6qts?
Old Jul 20, 2012 | 01:34 PM
MitsuRaider's Avatar
MitsuRaider
I think it has to do with how well you drain the truck. I noticed that I had to pour in a bit more oil when I did my oil changes in an inclined driveway vs a flat surface. Perhaps because I was able to drain the oil better when the car was a bit inclined....
Old Jul 20, 2012 | 02:16 PM
norma jean's Avatar
norma jean
are you saying the front is higher or the back is higher?
Old Jul 20, 2012 | 03:51 PM
Holbrook.Jeremy's Avatar
Holbrook.Jeremy
I would think front is higher since the drain plug I believe is pointing towards the back of the truck.....though I'm not sure now.
Old Jul 20, 2012 | 04:07 PM
MitsuRaider
Yes, with the nose higher
Old Jul 20, 2012 | 07:29 PM
novovictus1's Avatar
novovictus1
i had my nose pointing down, perfectly full right below the top hash mark line with RP.
Old Jul 21, 2012 | 09:31 AM
Holbrook.Jeremy
nose higher to drain all the oil outta the pan. I usually run a left over quart down the fill tube and out to flush any crud sitting on the bottom of the pan.
Old Jul 24, 2012 | 01:03 PM
varnerhba's Avatar
varnerhba
leaner the meaner
Old Jul 25, 2012 | 11:55 PM
cheeseburger's Avatar
cheeseburger
I know the 4.7 holds 5.7 litres of oil and the 3.7 holds 4.7 litres. or something like that.. I thought that was funny.... and a quart is .9466 litres...
Old Jul 26, 2012 | 07:54 AM
sdsdsd's Avatar
sdsdsd
My truck 4.7L magnum takes 7 quarts as well!
Old Jul 27, 2012 | 09:19 PM
novovictus1
Amen!
