no tail lights
no tail lights
Alright so I have a 2005 dodge dakota. And I have no rear brake/turning lights. I do have backup lights I believe.
I checked the bulbs, they are good, I even attached the bulb with the wiring harness/clip to 12v battery and it lights up.
The fuses look good, and I think I will need to do a continuity test on the lines? Or could there be a problem with the fusebox wiring?
Thanks in advance
Thanks in advance
alright, made some progress.
First off, the reverse lights on both sides work. When I brake, none of my lamps show. (tail and the one on top)
When I put on my lamps and brake, then only left(drivers) taillight is on.
And turning, they dont work.
Now I got grounds okay on both sides, but from the middle connector (pink/red on left, and white/orange on right) only the left one works. I did continuity tests for a while, checking from fuses and all, and I lose continuity past the fuses. Took apart the fusebox and there was a wiring harness, continuity works on pink/red like it should, but white/orange doesnt show anything.
Looks like I will have to trace the wire all the way from there to the rear end. Thinking if I can get this to be continuous, then atleast I will have both brake lights working. Then I will have to find out why turning lights dont work (I think it happened same time, so might be going together, however I am not certain).
For some reason my relay has a wire soldered to it, its weird and I don't think its supposed to be like this, anyone else have a yellow wire coming out of the parking lamp relay (i think its called)
