Rear block questions before install
I have my two 2" blocks and ubolts and im about to put them in. Is there anything i need to know before putting them in, and also my buddy said i might need shock spacers but hes not sure. Is this true do i need shock spacers for my 2" blocks in the rear?
Thanks
Thanks
If you are running stock length shocks, then no you will not need shock spacers.
Heres a tip:
After you have inserted the blocks, align and bolt up the driver's side FIRST. People run into a problem where the emergency brake cable fights them and prevents them from aligning the block's pin with the leaf pack if they happened to bolt up the passenger side first.
So, take up some slack evenly on both sides with the u-bolts, but then align and bolt down the driver's side (the side with the e-brake cable) FIRST, then align and bolt the passenger side.
Heres a tip:
