Headlight Lens 09 Dakota
Old Aug 24, 2012 | 05:21 PM
Sydeshow's Avatar
Sydeshow
Default Headlight Lens 09 Dakota
Hey guys, new to the forum here
Anyways was wondering if anyone has any idea how the heck you put the headlight lense back on.
I recently hit a yellow pole in a parking lot, and damaged the light beyond fixing so I need to replace the lens. The light comes out easy because its held on only by one of the three bolts.
Now I try to put the lens back in and the lens covers the two bottom bolts, it almost looks like I need to take off the bumper or something to get it? surely there is an easier way!
Any input would be appreciated, thank you!
Old Aug 24, 2012 | 07:33 PM
jasonw's Avatar
jasonw
Site Moderator
I can usually squeeze a socket wrench between the bumper and remove/install the headlamps. If you can't get it in there, then the only other way I know of is to loosen the bumper or remove it, so that it can drop down out of the way.
Old Oct 12, 2012 | 12:41 AM
trotterp2305's Avatar
trotterp2305
I used a 1/4 socket in between like jason said.
Old Oct 12, 2012 | 09:56 PM
Reject's Avatar
Reject
Like jasonw said, on my 05 (different headlights tho) I can get a screw driver in there, with 2 Extensions (like 5" ones) Ive seen the 08+ and it looks the same way
