Power Steering
Old Oct 11, 2012 | 07:48 PM
Holbrook.Jeremy's Avatar
Holbrook.Jeremy
Default Power Steering
Every morning when I go out and start my truck the power steering is very stiff. After I go about 10 feet it's back to normal and off I go. 2 wheel drive, I know it's either the pump or the rack. Slight leak on the passenger side but not enough to effect fluid levels in the res for the pump. Any ideas?
Old Oct 11, 2012 | 10:01 PM
Eimer123's Avatar
Eimer123
Tie rods (inner or outer) probably not the inners
Ball joints (top of bottom)
Intermediate shaft u-joints rusting up
Old Oct 12, 2012 | 02:54 PM
Holbrook.Jeremy
New tie rod ends (Outter), new upper and lower ball joints, no intermediate shafts (2wd). And it's only when the weather is getting colder outside.
Old Oct 12, 2012 | 04:37 PM
cheeseburger's Avatar
cheeseburger
Ball joints could just need repacking... it happens.
Old Oct 12, 2012 | 09:22 PM
Holbrook.Jeremy
Happened before and again after the ball joints, I didn't know if it's a sign of pump failing or rack failing.
Old Oct 12, 2012 | 09:48 PM
Reject's Avatar
Reject
I think he means the Intermediate Steering Shaft, Its know to seize up, Mine did, greased it, it now has 1" play, but doesnt bind. But it was also stiff all the time.
Old Oct 13, 2012 | 07:43 AM
Holbrook.Jeremy
I'm gonna grease the crap out of it today. Sooo annoying at 4am leaving for work and I can't get my truck out of my parallel parking spot because the damn steering wheel won't move.
