anyone hear of this before
Old Oct 23, 2012 | 10:10 PM
mulie4x4's Avatar
mulie4x4
Default anyone hear of this before
I have a 2009 Dakota and it has TPMS. I wanted to put on my winter tires so I got some used steel rims for cheap and they do not have the TPMS sending units in the tires. I thought it would be no big deal just have the alert symbol on all the time but I could live with that. Here is the problem, I took off the front drivers side tire off and put on the steel rim no problem all good tires turns, then took off the front passengers side tire and put on the steel rim and I could not turn turn the tire so I then tired to move to the truck and it started put it gear but would not go anywhere. So I took off one of the steel rims and put the factory rim on and it turned again so I took off the other steel rim and the factory on. What going on? The only thing I can thin off there has to at least 3 TPMS senors on the truck and it has a security featured not letting the truck move....Anyone?????
Old Oct 23, 2012 | 10:48 PM
Do the steel rims have a different offset?
Old Oct 23, 2012 | 10:52 PM
Reject's Avatar
Reject
I do not think the TPMS has any effect of drive-ability, since hte Sensors are a common failure point.
Sounds like off set, or something
Old Oct 23, 2012 | 10:59 PM
dakotaff's Avatar
dakotaff
Agreed, TPMS will not prevent your truck from moving. Your wheels are not 15" by any chance, are they?
And the question of offset above, too high of an offset will cause the wheel or tire to rub on something on the inside, possibly the brake caliper.
Old Oct 23, 2012 | 11:09 PM
mulie4x4's Avatar
mulie4x4
No they are 16 in wheels but I never checked the off set. I well have to have a look.
projektdirtfab's Avatar
projektdirtfab
Sensors inside of a tractor tire and leave it in the bed. Or put new bands on the new setup
Old Oct 23, 2012 | 11:15 PM
mulie4x4's Avatar
mulie4x4
Well the offset is the same the steel rims came off of a 2001 ram 1500. When it warms up I well have to put one on and see if its binding on something. Thanks for the info.
Old Oct 25, 2012 | 06:35 PM
Tygarys's Avatar
Tygarys
If you have a superchips tuner, you can download a option that can disable the TPMS until you swap back to your other tires.
Old Oct 25, 2012 | 09:15 PM
hendrixx324's Avatar
hendrixx324
check for wheel weights on the inside. There might be alot stacked on top of eachother causing it to catch on somthing
Old Oct 26, 2012 | 09:44 AM
TomZ's Avatar
TomZ
Usually any binding will come from the brake caliper. You may just need to dress the high spot(s) with a grinder, if the amount of material to be removed is small.
