Potential Dakota Owner
Old Nov 16, 2012 | 08:42 PM
madredr1's Avatar
madredr1
Default Potential Dakota Owner
Hello all,
Just joined this forum to ask a general question. Looking at ditching my 2000 S10 for a newer 2wd Dakota - V6 and 6 Speed transmission. It's a 2008. My question is I see a TON of reviews talking about how the V6 leaves a lot to be desired for hauling and towing, and I just want to confirm the truck will fit my needs.
I do a lot of ATVing, and currently I stuff one in the back of my S10 and one on a little 4 by 8 trailer. Occasionaly I will fill the truck with a weekend cooler, guns, the ATVs, and boatload of ammo, and targets. The S10 handles it fine, but will the Dakota deal with this just fine as well. I hate the s10 - it's been a nightmare for three years, and this Dakota is a pretty decent deal with lower mileage. Should I disregard the reviews and will it be ok for light hauling and towing needs?
Thanks in advance!
David
Old Nov 17, 2012 | 12:17 AM
gjmoran's Avatar
gjmoran
if u can get the v8, they get about the same mpg
Old Nov 17, 2012 | 02:00 AM
jasonw's Avatar
jasonw
Site Moderator
With the manual transmission, the V6 may get a couple MPGs better than the V8. However, they redesigned the 4.7L V8 in 2008. Just over 300 HP and better MPGs than the older V8 model, it is a much better option than the V6 in my opinion. It will also come with a premium price tag though, and they are harder to find. For the 2010 model year, I saw a few sites that stated approximately 70% of Dakotas were V6 equipped.
Test drive the V6 with the 6 speed. I think she'll do fine for your needs, but only you can determine whether you'll be happy with it or not.
Old Nov 18, 2012 | 08:45 AM
Growlor's Avatar
Growlor
Thanks to the magic of 2 year leases, I have had a 3.7L (2005) Dakota, a 4.7L (2007 - NOT the HO model) and am now driving a 2010 4.7L (which I am not leasing - plan on keeping this one.) All were 4x4 quad cab models with auto trannies.
I think the best of all of them for towing (never actually towed anything so take this with a grain of salt) would have been the 2007. The V6 was fine around town, but trying to get up to passing speed on the freeway was noticably slow and sometimes a bit dramatic on my morning commute: some bozo made my onramp merge into the FAST LANE which ends right before an overpass (so very little distance to merge) and it is uphill to boot. The 2010 is a screaming beast once you get it wound out, but it feels kind of gutless at lower RPM's - I actually had the dealership look at it a couple of times when I first bought it because I thought it might have something wrong with it, but all checked out fine.
Old Nov 18, 2012 | 11:37 AM
MonkeyWrench4000's Avatar
MonkeyWrench4000
If your S10 has the Vortec V6, it is a more powerful setup in an S10 than the 3.7L V6 in the Dakota.
The V6 6-Speed setup has 3.21 gear ratio, and it is good enough (I have this setup). It is about on par with a 5-speed 4 cylinder Tacoma.
I get around 17.5 MPG in mixed driving, mainly stop and go though. I have hauled 750lbs in the bed often and cannot really tell the difference. I have never towed with the thing though.
I may be wrong, but I think with a hitch the 3.7L V6 is rated to tow 3800lbs or so? Again I could be wrong. You shouldn't have an issue with the lifestyle you mentioned above, but I can't imagine any truck that couldn't handle that stuff.
Old Nov 20, 2012 | 11:43 AM
sdsdsd's Avatar
sdsdsd
DON'T PURCHASE THE DAKOTA IT IS JUNK!!!! Nothing but repair after repair! Struts, ball joints, transmissions, head gaskets, engine failure. Get a full size something or nother. You get about the same fuel miles.
Old Nov 20, 2012 | 06:03 PM
DaKoCuN's Avatar
DaKoCuN
It's actually out of production, but if u get good care of u truck u will have a truck for years over and over.
